android xperia m usb issue
need helppp
My phone is an xperia.m it has usb mass sto[Q] need helppp
My phone is an xperia.m it has usb mass storage mode. I conectd it to a dvd player n it worked. However it only works sometimes. I used a cut half of the usb cable n made my own wire. I conectd red blsck white green properly . My phone says usb debuging enabled yet nothing. Its supose to say msss storagr enabled too. If I fiddle it works but ite not anymore. Helpp. Im typin from phone so sorry. I needa mke this work I cnt buy a new cable from where iam right nw n I needa acces files on my sd card like this..
If USB works sometimes (like when you wiggle the connector), the connector isn't properly soldered to the board (inside the phone), and you'll need a repair shop to fix that. If it works when you move the cable, your connections aren't very good, and you'll need to fix that.
Heres photo
8
