Androwook 2.0
I loaded Androwook and didn't really see much customization. :confused: Sure, there was some when you actually flash it (i.e. kernel, speed, etc), but once it is flashed, it looked pretty much stock from what I could see. And some of the options that I chose didn't seem to be applied. For example, I checked off that I wanted TiBU installed...it didn't happen. I didn't even check to see if it overclocked as I requested.
I loaded up Team Broccoli's AOKP ROM last night and really like it. The best feature is the ability at add some shortcuts to the task bar. BTW, flashing ROMs through the goo.im app is pretty sweet.
http://pcb.team.broc.co/li/aokpcb
