angrybirds graphics problems?????
mk555
I have a samsung moment.I downloaded angry birds and on every board there is a mountain or somthing that the objects are on the mountains are just white like theres nothing there????? why is this happening?I tried uninstalling and downlaoding three times with the same resutls?pls help would like to have the game working properly.
I have the same problem on my Galaxy Spica. First I thought it was intentional, that there was supposed to be invisible objects, but that's clearly not the case.
from what i have read its your phone not being able to cope with all the graphics i have the same problem on the hero not much you can do , rovio(people who make it) have said they can`t fix the problem so either get a new phone or live with it i`m afraid , you could try putting your phone on airplane mode but it did`nt help with my hero so no promises
have you tried this thread? : http://androidforums.com/samsung-moment/201259-angry-birds.html
i also have the lack of graphics and some slow down while running this game on my moment and i've yet to sit down and try out this solution of installing this :
Quoted from chibucks "use the GL drivers from samdroid - basically, you need to replace your /system/lib/egl/libGLESv1_CM_fimg.so file and those brown textures will appear."
hope this helps... i'll let you know how it goes once i sit down and try this out
I had the same problem on my Hero.
I'm guessing the phone isn't powerful enough to handle it.
It has nothing to do with your cpu speed. It has to do with 2.0GL(sp?) graphics. Most low end/ older phones do not support this. We have version 1.6/1.5
