Apps Animated Sprite Using XML?
safibaba
Hi all
The Android docs shows a way to create an XML definition of an animation like this:
PHP:
<animation-list xmlns:android="http://schemas.android.com/apk/res/android"
    android:oneshot="false">
    <item android:drawable="@drawable/img1" android:duration="200" />
    <item android:drawable="@drawable/img2" android:duration="200" />
    <item android:drawable="@drawable/img3" android:duration="200" />
</animation-list>
I have been trying to create a Drawable from this XML like this
PHP:
Drawable sprite = (Drawable) getResources().getDrawable(R.anim.sprite);
And then draw it on my canvas in my SurfaceView like this
PHP:
sprite.draw(canvas);
It draws the first image - but it doesn't animate through the images specified in the XML.
I thought maybe I needed to make it an AnimationDrawable like this
PHP:
AnimationDrawable sprite = (AnimationDrawable) getResources().getAnimation(R.anim.sprite);
But it still didn't animate. So finally I thought maybe I need to call start() on it, but that gives me an error.
Am I just barking up the wrong tree here? Is it not possible to draw an animation to a canvas in this way? I have seen a tutorial which uses a sprite sheet and the setbounds method to do this, so maybe it's just not possible using the XML route?
Hi Boogs - actually yes I was. I didn't know I shouldn't be :o.
So is this a valid way to draw animations when using a SurfaceView?
HOWEVER - the start() thing doesn't seem to be where it falls over, because I think it doesn't even get that far.
I am getting a classcastexception here
PHP:
I don't suppose you know where I could find an example of doing this correctly?
Well, it seems usually calling animation "start" or similar calls in onCreate can be problematic because all the views haven't finished their "setup". Check out the note at the bottom of the Android developer 2D graphics page which basically says the same thing.
As for an example, I don't have any great examples for you. But, you might want to check out the Android examples Jet Boy or Lunar Lander for some examples of drawing on a canvas SurfaceView. Then integrate your AnimationDrawable in a similar manner.
Boogs
Thanks for the tips Boogs..but I just can't get it to work at all.
I tried calling start from a separate thread, even calling start() from an onTouchEvent to make sure it gets called after the onCreate is finished..but I just can't get this damn thing to animate...
Is it something to do with the setBounds call?
res/anim/sprite.xml
PHP:
<?xml version="1.0" encoding="utf-8"?>
    <item android:drawable="@drawable/sprite1" android:duration="500" />
    <item android:drawable="@drawable/sprite2" android:duration="500" />
    <item android:drawable="@drawable/sprite3" android:duration="500" />
    <item android:drawable="@drawable/sprite4" android:duration="500" />
    <item android:drawable="@drawable/sprite5" android:duration="500" />
</animation-list>
SurfaceView
PHP:
public void surfaceCreated(SurfaceHolder holder) {
 sprite = (AnimationDrawable) getResources().getDrawable(R.anim.sprite);
 sprite.setBounds(0,0,sprite.getIntrinsicWidth(),sprite.getIntrinsicHeight());
public void startAnim(){
   Log.v("APPLET","Start Anim");
   sprite.start();
Main Activity class (which creates surface view)
PHP:
@Override
public boolean onTouchEvent(MotionEvent event){
   gameScreen.startAnim();
   return true;
It outputs the log message fine, but the animation never starts So frustrating :(
Safibaba,
Sorry that didn't work. To be honest, I don't know why it won't work. My only suggestion would be to put your animation into an ImageView in an Activity and see if that works. If it does, then at least you know that your XML file and the like are working fine...
I fixed it Boogs - I find the docs a bit obscure sometimes ...after googling for the best part of a day..it turned out I was missing the addCallback() method to make the parent thread schedule updates to the animation. I thought the animation handled its own frame updates!!
Wow, it seems like they should've made that easier, or at least documented it better if it's that hard. Either way, I'm glad it worked out for you.
Hi, safibaba
I have exactly the same problem... How did you add that callback? I've been stuck with this for 2 days...
Thanks!
