Anker batteries.
mattsd
Member
Can anyone tell me if the anker batteries for the sprint galaxy s2 epic 4g touch will work with the virgin mobile s2 epic 4g touch variant?? I'm desperate to order some batteries and a charger but anker are being quite slow about getting back to me. Thanks for any help!!
yes they will, i have one.
Just so we're straight, I'm talking about this specifically:
Amazon.com: Anker 2 x 1800mAh Li-ion Batteries for Samsung Galaxy S 4G T959v,Sprint Samsung Galaxy S2 II Epic 4G Touch SPH-D710, U.S. Cellular Galaxy S2 II SCH-R760 + Free Anker Multi-purpose USB Travel Charger: Electronics
I only ask because I emailed Anker and they told me they don't make a battery for my phone...
Under the battery on my phone it says SPH-D710, which leads me to believe that this would work...
Thanks again anyone for any help.
Yes that will work.
Excellent. Thank you very much for the help. Do you know if it is also possible to charge the OEM battery in the external Anker charger with no ill effects?
I do it all the time with my ankers! They stop charging once they are fully charged. There also will be no ill effect by charging your OEM battery with the external charger.
