Mike Evertzen
Hi,
I have a dual core Android box that I purchased from China - running on 4.2.2. I'm getting this annoying system alert "Warning - System configuration is inconsistent with the production configuration, please contact your supplier, thank you!" that flashes constantly until I turn the box off and reboot. It then goes away - sometimes for several hours other times only 30-60 mins but eventually it comes back.
The box runs absolutely fine when this message is not flashing. Does anyone know where I can go to in the system to disable this message?
Many thanks
Mike
Many thanks
Mike
