Last time (I promise!).
I've flashed Redux 1.2 which is working fine, I just can't get a custom animation to work.
I've used adb to push the zip to /system/media which is where the original animation was, however on reboot I'm greeted by a black screen.
I made the animation using an existing one and simply altered the background colour, this original animation doesn't work either.
I've tried using a uncompressed zip (store) but this doesn't help.
The original did work when I had the stock ROM however. So I'm wondering if it's something specific to Redux?
Any ideas?
Thanks again.
Edit:
Solved:
- Was not overwriting zip at /data/local/
- Images were not 24 bit (removed alpha layer to correct).
Any ideas?
Thanks again.
Edit:
Solved:
