Silverjunkie
Howdy folks,
Yesterday, I was the proud owner of a sleek little TCT.Alcatel OneTouch A554C, formally know as a Virgin Mobile Venture running Android version 2.3.5.
It was successfully and surprisingly easy to root by utilizing 2 cool little apps, Ministro and Poot-Debug.
After root, I subsequently downloaded some root tools (eg., Titanium Backup Pro, Superuser Elite, System App Uninstaller).
That was last week.
Yesterday, I got a bit cocky. I needed to clear up some internal memory so I used "System App Uninstaller" to uninstall a few apps. If I remember correctly, the apps were as follows: Google Maps, Google Maps Street View, Calculator, Digital Clock, Setup Wizard, Android Live Wallpaper, Live Wallpaper Picker, Magic Smoke Wallpaper, Music Visualization Wallpaper, and the TouchPal Keyboard French and Spanish Language Packs.
So far so good, right? However, I believe I may have snarfed-up when I uninstalled the Setup Wizard. But I'll get to that in a minute.
Now with Titanium Backup, I moved some apps to the sd card. Included was the stock launcher, Smart Launcher Pro, SPB Shell, AVG Anti-Virus, and Superuser Elite. Then I rebooted through Titanium Backup and I haven't viewed any pornographic material since!
After reboot, the phone got stuck on the final boot animation frame. I panicked, pulled the battery, booted into recovery then rebooted a 2nd time.
This time it booted to the pull-down lock screen. I unlocked and seen:
"Sorry! The application com.android.setup wizard has stopped unexpectedly. Please try again." Along with a "Force Close" option. I forced closed and the screen went black with the exception of the status bar. The phone is still on but otherwise...nada.
When I press the power button, same thing happens: pull-down lock screen, screen goes black. Or sometimes, it will turn on and boot loop.
Major panic time!!! I booted into recovery again and performed a factory reset to no avail.
Another clue to note: I can connect & access the sd card via usb to desktop.
Also, I did have the good sense to backup all apps, system and user, through ES File Explorer and stored them both on sd card and in the cloud via Yandex Disk prior to this bricking fiasco. Now, what do I do with them? I now realize it was possibly a mistake moving all 3 launchers to the sd card. How do I get the stock launcher back to the phone?
Or, should I:
1- Attempt a base rom reinstall or
2- Attempt a custom rom install or
3- Use it solely as a time piece/mass storage device or
4- Throw it very hard and very ******* far away from me!?
That was last week.
Or, should I:
