ScottSilver
Hi Folks. Running Eclipse Gallileo 3.5 on Vista. I have successfully installed all the components successful, both the SDK and thru Eclipse, the ADT (no problem with the link) and Eclipse shows the ADT as installed BUT...
I see nothing. No "Android" in Preferences, no Android Projected in the create menu either. I thought I was using the correct versions of everything. I have reinstalled everything, but nada.
I've noticed I'm not the only one with this issue, but none of the solutions seem to work. Note: the emulator comes up if I launch it, so the SDK looks ok. What is with Eclipse??
