channELcee
Ok I have tried the flash 10.3 installation with no joy so I tried the 10.1 with the 10.2 update way and still no joy. Now my first reason for wanting flash was for tv, however with tv catchup mobile not needing flash as their site runs an in built flash like you tube the need for iplayer etc dont matter. I was content (for bout ten mins) till I tried SKY POKER and da da daaaa the flash ghost strikes again.
I have used cm7 as its got flash 11 in built but had user issues so I changed to a few others before just going back to GALAXY ACE gingerbread 2.3.6 stock which just simply works rom wise. When I install the flash players I did simple install apk file then reboot. Is this right although my phone is unrooted from changing back to stock. Does that matter? Anyway on skypoker as im sure others have found I get a message saying
You need at least adobe flash player 7.0.0 you are currently using 0.0.0
I have found a normal old sofware site with 7.0.0 but this is for pcs not andriod obviously as they werent even about lol. Is there anyway of installing a 7.0.0 zip file? I know thats wierd but if thats the earliest form of adobe that works for sky then I will be happy if it can be installed. Please help and if anyone has managed to get sites like sky to work please let me know how. (also gutted as I paid money on poker tourney) lost it without playing grrr. Technically I think samsung owe that to me for advertising a phone that is flash compatible WHEN ITS BLOODY NOT
I have used cm7 as its got flash 11 in built but had user issues so I changed to a few others before just going back to GALAXY ACE gingerbread 2.3.6 stock which just simply works rom wise. When I install the flash players I did simple install apk file then reboot. Is this right although my phone is unrooted from changing back to stock. Does that matter? Anyway on skypoker as im sure others have found I get a message sayingYou need at least adobe flash player 7.0.0 you are currently using 0.0.0
GrahamF.
