Vildy
After Upgrade I lost my Quick Setting/ Notification Panel..Got NO help from Asus Support. Don't know if anyone else is experiencing this problem but here's the sequence of events.
Before JB update, Quick Setting Panel/Notification screen came on after Boot up.
After JB Update no Quick Setting/Notification panel. Period!!
Just by happenstance, I had removed by 64g MicroSD card and booted up. Bam!! QSP appeared.
I powered down and installed the MicroDS card. Powered back up. You got it.. No QSP..!!
Just by happenstance, again, I plugged in my earbuds. Bingo, QSP appears. Earbuds out. QSP disappears.
Something is going on between JB, and the MicroSD card which disables the QSP
Same scenario over and over. Now, the only way that I can get a Quick Settings Panel/Notification screen is to plug in my earbuds or do it the hard way and go into "Setting" to adjust screen brightness, turn on/off WiFi, Bluetooth, etc instead of a simple tap of the bottom of screen for the QSP
