Root Another Mystery: Where is Titanium Backup Pro?
PHP87
I have installed Titanium Backup Pro on my LG Spirit and it doesn't show up under Apps, Downloaded or Widgets.
It does show up in Settings > Apps
How do I put this app on my Home Screen?
My phone is rooted, but for some reason, I can't find anywhere do find the icon and drag it to my Home Screen.
It depends on what launcher you are using. If it appears in settings>apps then it is installed. Would this be the stock messaging app? What you need to do is get into your app drawer and long press the messaging app icon and you should be back at the home screen. Drag it where you want and release your finger. It should now be on your home screen. If you use another launcher, please consult the launcher's documentation for adding apps to your home screen.
It wont be listed as titanium backup pro. The "pro" is just an unlock. It will be listed in your app draw as titanium backup.
OK, thanks. I was going nuts trying to find the Pro version but could only find the backup, non Pro version.
But I seem to remember having it on my Homescreen on my LG Motion, but I no longer have that phone it so I can't check.
Thanks for unraveling that mystery.
