Help Another poor battery with battery stats
bigyid
Member
Ever since ive had phone my battery has been terrible,i have just installed GSam battery monitor and found a few things keeping my phone awake,can anyone have a look and tell me if all looks ok or maybe shed some light on what i should do to make battery better.
10hrs is not to shabby, especially when your awake time and screen on are pretty in-sync, other sync options like email, social shit, games, etc would benefit on making them wait longer between syncs.
from what i can see, it seems like user, 50% is screen... im an avid user and get 6-12hrs depending on what im doing...
if you feel it is a faulty battery, grab a multi meter, once the phone is at 100% check the batteries voltage, it should be around 4.2+v, anything less means its degrading.
I only have twitter and gmail on phone and twitter is not set to sync, i have looked at google mail settings but cant find how to change push time's ? i seem to be getting loads of wakelocks for some reason
The cell standby seems way too high..
Cell standby is a lie by 10x. Go to email or an account. Hit menu. Settings. Click an email. Preferences. Do you have your screen all the way up? And i would understand if it was screen off and dying in 8hrs but like i said your pretty in sync with the awake and screen on. Something turning your screen on or are you? Also if you have lte/4g it eats up battery at times when browsing the web or using data (weather widget, background services, etc)
Screen in half way, only account syncing is gmail no other mail or social sites, I've even unticked every option in map settings but that still shows as wakelock.
Battery only lasts from about 8am to 7pm with moderate use during day e.g.: internet and mail
I have looked in email settings but no luck finding push settings
