Another "problem loading widget"
JimK57
Whenever I turn on our phone (we turn it off at bedtime), as it goes through the boot-up process a "problem loading widget" message appears at the top of the screen for a few seconds and is then replaced with the Google search bar.
Do I really have a problem or is this just some strange idiosyncrasy?
If the Google search bar is the widget that is having a problem, then no, it's just indicative of something taking a while to load during boot, interrupting the widget. As long as it eventually shows up and works fine, then I wouldn't worry about it.
If it is some other widget, then i'd make sure that it isn't installed to the SD card, which can make widgets behave abnormally or crash.
