Help Another Question about Factory Reset
When I'm doing a factory reset on my razr maxx with ics, will it make a difference in the reset if the external memory card is out. I saved all my pictures and contacts on the card or is there a better/ safer way to do the reset.
Thanks !
Love that Razr Maxx!!
Just make sure you pay attention to the options before you hit "start reset". You get one chance to make sure you don't select "format card".
So, if you're truly worried, feel free to take the card out to be extra certain you don't get a case of the butterfingers.
^^try reading that and not thinking about Dr. Hammond of Jurassic Park saying "butterfingers"
