If this is a double post, I'm sorry. I thought I posted first message, but as soon as I hit enter it took me to main forum page
Anyhow.... I'm running FE19 rooted, with CWM and Link2sd.
My question is: What did I do wrong and how can I do it correctly?
I got a new 32gb Sandisk Ultra MicroSD card. Obviously I couldn't wait to try it out.... Shut down phone, went into cwm, took old card out of phone, copied all files on it to a new file on the computer (which is running windows7 64bit).
Put new card in phone while still in cwm, formatted card, partioned it using largest available amount (4096?). Took card out of phone, put it in pc and copied all files that I had just posted. Put card back in phone, mounted sd card and ext. rebooted. My programs that are on sd card don't show. (along with freezes that darn update notice). Look at sd card and it shows all files. Go into settings/storage and it shows total space 25.90 gb, available space 25.49 gb/ internal storage 73.50 mb (that's not right is it?).
Rebooted phone, went back into cwm, wiped dalvik, made sure sd card was mounted and rebooted. Same thing. I must be doing something wrong. I just don't know what....
Would appreciate any help. Don't want to put new card in hubby's phone until I can figure out how to make mine work correctly.
Oh, could the problem be that when I partitioned old card it was set at a lower partition?
I didn't format old card yet. (Thank goodness) But sure would like to use new one instead.
Update: Put old card back in phone and apps still aren't loading???Now I know I missed something. It's not reading either card when I reboot. It's got to be something I need to do in cwm, right? or do I need to start over on reinstalling aps?
-no such luck. I had all of about 1/2 hour to get everything reinstalled and new card working before he had to go to work. (thank again LordVincent for walking me through that before, made it much easier when I had to do it again).
, but thank you for the suggestions. I can always go back to the smaller card if these give us problems.
