Another Sync Problem.
dme109
I have read about every forum that has to do with Android devices but I have not come across this problem so here it is.
I have a MAC and I have managed to sync ICal with Google Calendar, my issue comes when I try to get the calendar (Google) to sync with my phone. This should happen automatically but it does not. Now let me give you some things I have tried, I went to Manage apps/Calendar and cleared the cache. no go, I have done the shut down and remove the battery. no go, I think the problem might be in my setup between Google and the phone. When I go to add a calendar I do not see the Calendar name that I use in Google, I get a bogus email address as my only choice.
OK reading this I see that I might not be making sense, if you think you can help ask a question and I will answer it to the best of my ability, playing 20 questions might just solve my problem.
