Root another way to get rid of system updates on any rooted mod
cwhatever
Life Goes On
this has gotten me curious, so i went into autostarts and enabled the(google services framework/SystemUpdateService$Receiver) which i disabled 6 months ago, and as soon as i did and went back to homescreen bam update notification that it was blocking. so i went back in and disabled it again and cleared cache and cleared notification bar and rebooted, been hours now and no update. this proves to me it was doing its job of disableing. without that working i will never see any system update ever. now those of you that did that prop.build, your phone now says fe16 and may not even be on that. mine still says ej06.
for those who wanna do it this way just use autostarts(from store)
1)open app
2)let it load up
3)click, after startup, and scroll down to google sevices framework(3rd one down for me)there are multiple ones
4)click on it, it should say (SystemUpdateService$Reciever)at the bottom of options
5)click disable then go into cache folder with a file explorer and delete, update zip, reboot and good to go.
also blood if want to stop them in next update maybe just delete that and should be good.
i know some of you don't mind the build prop, and neither do i, but have already done it this way and some others now have a different option, like noobs that don't know about terminal, or are afraid to mess with build props.
i had forgot about doing this and when i was working on getting swap going,which i did, by redoing everything as soon as i got all going wham that update was back so did all this again and now gone again on ctmod 3.6, no updates ever for me. and this will work on any rom or stock rooted.
