ok this is wrong...when using phone it works fine, But when its charging and i have an incoming call i cant seem to answer it.
Its like the phone rings, normally you have to slide the ring up to answer, but the screen stays black, to make the screen light up you have to press the power button which ironically also ends the call.
So how do answer calls when the usb cable is connected to charger or pc
