I bought a Wacom Bamboo stylus for my Nexus 10 so I could replace my notebook in meetings at work. But, as I feared, you have to make sure not to touch the screen with your palm at all. There is an app called "Lecture Notes" that claims to have palm rejection, but that feature works badly at best.
It seems many people keep a lens cleaning cloth under their palms and have success with that method, but I don't want to have to fight the cloth and worry about keeping it under my hand at all times. Therefore, I am thinking that I will wear some sort of glove. First, I wanted to see if anyone tried to solve the problem with a commercial product but all I could find was this:
Hand Glider
The Hand Glider, Tablet Glove, iPad glove,
I am not thrilled with the look of the product in various shots. For the price, it looks cheap and ill-fitting. Plus I had a hard time finding actual reviews of the product and one I did find was a 2/10.
I also found a product called SmudgeGuard that is similar, but it is designed to prevent ink and graphite from getting on artists' and writers' palms or to prevent hand oils from getting on Wacom tablet screens. It is not designed to prevent the detection of a palm on capacitive touch screens. I e-mailed the company and they said they had tested it on iPads and it does not work adequately for that purpose. They also said they are aware of demand for such a product but had spent time over the previous year trying different materials and were unable to find a completely reliable solution to the problem.
Has anyone tried a Hand Glider? Does it work okay? Are you aware of any other products that do the same thing?
Thanks in advance.
Hand Glider
Thanks in advance.
