DsyMnapTic
Android Expert
Purdy Purdy Please...
I don't got recovery anymore. That's the point. I'm completely bricked, only thing it boots to is the green Android. No FTM no nothing
Hmmm, kind of the same predicament I was in, however I couldn't flash anything, nor boot anything. Also no I'm no longer on the old Awe I had. I did run into problems with this new one again, though I'm unsure of the cause this time. Seems to have been caused by trying to flash recoveries through recovery, repetitively. I don't know, but I do know the recovery got corrupted some how and had to reflash one with the Rashr app. I'm beginning to think that's the safest way to flash recoveries anyhow. The only reason why anyone would need to in the first place (I'm thinking) is to flash older ROMs based off stock.
Okay so apparently I shouldn't jump to conclusions so quickly. This time I was able to repair my phone with brittnearl soft brick fix (thank you very much) last time it was just the corrupt data partition that kept me from fixing my old one. Now however, I want to sort some things out. If I'm correct, you need older recoveries to install every ROM except for CM11, because of the updater binaries, is this right? Also have any of you others had problems with flashing recoveries over one another.
Hmmm, I found a culprit to my boot loops. Before I used to be able to flash and use any kernel, now anything BUT a stock kernel within a ROM, causes my phone only to be able to boot to the green android. Once again, I used to be able to boot and run these kernels all the way up to the 1.9ghz one.
Kernels are specific to rom eg: stock based roms, cm roms, etc... Oc kernels are the sameOkay...phew, I got it...I GOT IT!
TWRP has issues flashing to the boot partition. I flashed back to stock rooted B05 with Philz and then flashed a kernel again just fine, no problems whatsoever. TWRP is the culprit to the phone getting stuck in a boot loop after flashing a boot.img. It has to be.
