Root any custom recovery for pantech pocket??
this is ******deeeddd.....
so i root my pocket and install v6 supercharger.. screen becomes unresponsive... my wife thinks she deleates it and ends up removing the pantech launcher.... so i find amablejaquez stupid ass recover.img and i flash it with fastboot and the stupid ****** put a wrong recovery.img now my homebutton and notifications dont work and i cannot get back into recovery after i tried to flash recovery... ****... called pantech no help called att no help "hardware issue" they said
Hi
And what will you do with a stock recovery image? I can provide you with that. I just pulled a boot.img and a recovery.img from my Pantech Pocket P9060, but I don't know what to do with them.
I you find a solution, please let me know.
Here the links:
stock recovery
https://www.dropbox.com/s/tuyehhf6nw148vj/recovery.img
boot image:
https://www.dropbox.com/s/b6zm253m8zeiee4/boot.img
Good luck!
I'm trying to restore my Pantech P9060 with the restore.img you posted using AIO Flasher but when I try to boot my phone into fastboot the screen just says 's/w upgrading' and stays like that until I pull the battery Also AIO Flasher asks for the partition and I don't know if I should choose recovery or system (if i ever solved the fastboot problem)
Did you ever solve this problem because I need to restore stock rom on my pantech pocket I downloaded the amablejaquez recovery.img and flashed it using fastboot to my recovery partition now the phone is unchanged except i can no longer boot into recovery mode Please help if you can thanks
