Help Any fix for screen scratches?
It's a scratch not a crack so I'm still going to be able to resist the next big thing but I'd like to try to fix it.
Anyone have any success with any of the cures available?
I ended up with a scratch after I dropped my phone on my driveway and stood on it! The factory plastic screen protector split and I got a decent scratch from a rock. The scratch was not the end of the world but noticeable. I ended up buying a tempered glass protector and after putting it on can no longer see the scratch, so this might work for you.
Do you know what kind of materials the glass is made from?
Might be easier to find a solution if you get that info.
