Help any help please (flytouch 3)
Hi guys just bought my first android tablet from ebay its a 10.2" TABLET PC,SUPERPAD 3 ,FLYTOUCH 3,ANDROID 2.3, 8GB. I have been having a few problems getting the sd card to load. I have tried 4 different sd cards and none of them work. When i insert the sd card it pops up reading sd card then nothing i go into the settings then to sdcard & device storage and all that shows up is internal device storage no sd card. I have tried to use apps2sd but that doesnt work either. I contacted the seller and he told this was normal and i would have to use a file manager to locate the sd card on the tab.
I am at a loss here as i have rooted my hero and my galaxy s2 and never had a problem using my sd cards or app2sd or anything like that. I am just wondering if this means the tablet could be a clone or a fake.
I would be grateful if someone could please give me some help or information on this
Thanks
Thanks
try downloading Root Explorer (File Manager) , you already have a file manager it will open your internal SD card and you can locate SD card1 which will be your external sd card , Udisk1 and Udisk2 are the usb ports ... i recommend you to get Tim6a after you make sure that your sd card is working fine
Here is the firmware for the tablet when i go to about device
Model number : Android Tab10
Android Version: V2.3 2011-12-19 (001112)
Kernel Version: 2.6.329 root@wanghua-desktop #289
Build Number: FRF85B
For information on firmware for this tablet I suggest you look HERE as there is a lot of development happening there.
For your problem with your tf card, do you have MyPad application? or Root Explorer?
MyPad calls the external tf card udisk1, rootexplorer calls it /sdcard1
open either file explorers and then insert the card....
your tablet is no more a clone than EVERY other Flytouch!
