Root Any ICS/JB ROMs without the data connection dropping problem?
proc
Member
Hi all, has anybody come across an ICS/JB ROM wherein the data connection does not drop from time to time until the user has to do something about it?
I am seriously bored of gingerbread, already tried cm9 with problems like this which made me switch back to stock.
Any help would be appreciated.
CM9 I believe is not fully stable. Try CM 7.2, or even CM10 (Not fully stable yet but I don't have any data problems)
Thanks for the quick reply caro332, i believe i did try cm10 from here but i found system wide, the scrolling was very choppy... is it the same for you? If not then could u point to which ROM u r using?
