Any issues changing SD Card when using App2SD and/or Link2SD
gelige
When using App2SD and/or Link2SD, is changing to a larger SD Card as easy as powering down the phone, copying the files from the smaller to new larger SD card, insert and restart.
Maybe its a question too simple to ask, but I'd like to know if there are any gotchas
I use app2sd and had no problem switching out my 2gb microSd card with a 32gb card. I unmounted the card, turned off the phone, removed the card, copied it's contents to my compute (phoneSD folder), copied the contents of the old card to the new card, placed the new card in my phone and shortly after starting up everything was working fine. I have an LG Optimus T phone.
