Hello, I'm looking for a photo app that has great flexibility in post-processing.
I've checked out Camera360 Ultimate, Colour Touch, Vignette, and Photo Illusion so far.
What I'm looking for specifically is an app where you can control fx, like Tilt Shift, with more precision. I'd like to be able to determine WHERE to orient the focus, and HOW WIDE the blur should be, while looking at the photo. I also want a post processing program that I can adjust the Brightness, Saturation and Contrast while looking at the photo. Vignette can adjust it, but I have to set the levels with guessing, and then look at the results.
I'm aware that you can use the tilt shift in the camera mode while taking pictures (I am using the HTC Sensation), but that is frustrating, as it has to be adjusted before I take the photo. I want to take photos while life is happening, and the process them later using precision control of Tilt Shift fx.
If it helps, I am coming from an iPhone and was using TiltShift Gen on that platform. I loved that simple little app! All the photo apps I've found so far do so many things, but not what I want.
Any suggestions?
Thanks in advance!
Any suggestions?
Thanks in advance!
