Help Any solutions on memory problem
aceuser
Member
With ace its such a beautiful device, but it has a memory problem when we install few applications it says memory full in some applications only. hardly few apps can be moved to sd card but it seems of no help
I have installed 30 apps and found no problem of memory. Of course, there is a memory limit of the phone, you can't run too many apps at the same time. try to kill some with the task killer to save memory.
Guys, can you suggest good application to optimize the Samsung Galaxy Ace performance. And to answer the problems such as: how to prolong the battery life of Galaxy Ace, how to extend and install more applications and games, how to make it still fast and responsive. At least 10 guys. Thanks!
use superone click 1.7 to root ur ace. n then u can move some apps to sd card which wer not able to move b4. :) :D
