Any way to increase S4's max volume output?
c0ldpr0xy
Hey, so I noticed the volume on my earphones is pretty low, is there a way to increase it? I've maxed out the settings though but it's still way too low. S4 runs on Android 4.2.2
Thanks.
Are you using the stock Samsung earbuds that are supplied with the S4? If so you might be better asking in the Galaxy S4 section, as I've not noticed any other complaints so your device may have a hardware fault.
Yes, I thought of that and I tried the stock earbuds on a different device and they seemed fine. I think it's an Android issue that's why I am posting it here.
