Hey all,
Quick question,
Is there any setting that allows the screen to stay on and not time out? Looked in the display menu and the longest is 10 minutes. I remember that my Evo had a option to stay on if the phone was plugged into a dock or charging cable.
Thanks!![]()
Not to be rude, but why would you want the screen always on?
I'm in the same boat. It's not that I necessarily want it on all the time; I don't want it shutting off on its own at all. This forces me to turn it on + unlock frequently during use, which is unnecessary and annoying.Not to be rude, but why would you want the screen always on?
The application Screeble Lite works has worked well on my S3 since I got it. I used it very frequently on my DX when I was doing reading on my device. I'm not sure if the OP has tried to download it and run. It's really easy to turn on (when you want your screen to stay on) and off (when I want the screen to time out per normal settings).
StayAwake didn't work for me for some reason, screen kept turning off still.
I've been using https://play.google.com/store/apps/...t#?t=W251bGwsMSwxLDEsImV1LnRoZWRhcmtlbi53bCJd and it's working well.
