Help Anybody having trouble with voice input?
Garrett67
It works for me for a bit but then I get the animated circle and the prompt never comes up. Then if I back out of it and come back into the keyboard, all I get is a click when I hit the microphone.
The only way to get it to work is restart the phone.
hmmm
no issues yet.
I have issued commands without a problem. I have also voice to text(ed) without a problem....
just to verify, you mean when we hit home twice right?
you have to make sure you download all of the necessary software for it. see the settings for the download.
i too had this happen to me a couple of times yesterday. I haven't really troubleshot it yet though. If it persist in a couple of days i will. I know the network was hammered yesterday so i wasn't really concerned if there were minor issues here and there.
hmmm
no issues yet.
No, I mean when you're in a program (Text, email etc) where the keyboard is. The little microphone, I guess you could call it speech to text.
check the settings first. Then try redownloading it. Its free. Something may be corrupt. Tts
try this:
download astro file manager.
open it browse your system folder
go to apps
find tts
extract tts to a location on your sd
reboot phone
go to tts location on sd
reinstall
check if it works
hopefully that helps you without having to fac reset
Not to sound dumb (even though I do), where are the settings for it and where do you download it?
Are we in fact talking about the same thing?
dont worry man, we all have to learn sometime.:)
forget the settings, just go to the android market and download tts. This may not work. but its worth a shot. install tts, then reboot phone.
check if your stil having issue.
if this doesnt work, try my next post(#10).
what we are trying to do is reinstall the tts without having to FACTORY RESET . i apologize if the second method doesnt work, because the only solution THEN, would be to fac reset
I'll try that, it will take awhile to see if it works since rebooting it fixes it for awhile.
Thanks for you help :)
