CreeDorofl
Let me know if this isn't the right forum... not even sure if this is the
best site to ask, but I figure thousands of you must use car chargers daily.
Maybe you've noticed the same problem.
All of my chargers die within a month. I've tried various cheap
ones from walmart and radio shack.
On the adaptor plug that goes into your car... When I first buy one,
the metal prong in front and the two metal braces on the side are springy,
meaning if I push them in, they pop right back out.
When one finally dies, and I push them, they stay pushed in.
So is this normal for anyone else? I don't ram them in there or anything.
But I do insert and remove them a lot because I heard it's not good
to leave them in the car nonstop. Maybe that's bad info?
Can anyone recommend a brand that will last like a year?
