Anyone Else having WiFi glitches?
anubis2048
Whenever I put my phone to sleep for long periods of time, it turns the WiFi off and when it is waken from sleep the phone refuses to connect to WiFi. When I check the WiFi settings it claims that there are no networks available. Switching WiFi off and on again fixes it. Anyone else having this issue?
I had terrible issue with my last phone LG Stylo (uhggg..) but not much with ZMAX PRO.
Some say flashing network setting reset from Backup & Reset helps, some say using legacy dhcp client from Developer Options helps. Or it might be your modem / router problem :(
