Anyone else NOT using the battery cover?
Jerry-rigged
Howdy gang-
I am about a month into my Nexus ownership. Overall, loving it. Previous phone was a Moto Droid (origonal) that was rooted, rom'ed, over clocked, under volt'ed, the whole stick. So far I have not felt the need to do anything to my GNex - it is smooooth and fast. but anyway -
Has anyone else quit using the battery covers? I have the extended battery and 2 normal batteries, and the 'standard' hard case with kickstand that VZW gives with most phones. I week or two ago, I figured out that the hardcase will fit with the extended battery, if I leave the phone's back cover off... Looking thru the holes in the kickstand, I can see the battery - it is a snug fit (can't fit a piece of paper in there)but it does not seem to be binding...
Anyone else do this? Any issues to look out for? What is the over/under on how long till I kill the battery this way? :)
Howdy gang-
If it's super snug I would think the only issues you could run into are dust/crud/lint working its way into the back of the phone and if you dropped it (sudden jolt) could jar the battery loose momentarily and power the phone off and/or reboot it. I wouldn't carry my phone this way, but that's just me :)
Last night was the first time in a few weeks I felt the need to swap batteries. When I pulled the hard-case off the phone, there was a decent amount of pocket-lint around the battery and SIM card slot, but it all blew off easy. Today I am running the standard battery for the first time in about three weeks. We'll see if I make it thru the day without plugging it... :)
i wouldnt be too thrilled about not having the battery cover on, cause lint can cause some issues with the connectors in the battery, and hardware inside the phone
And just make sure it's not putting pressure on the screen. I had the DX extended battery with the regular battery cover over it when I was using it. It fit fine, but when I dropped the phone one time from pocket height onto wood floors, it made some black dots/ lines in the screen. I think it was because the battery was putting more pressure on the screen.
Great point I would definitely check for this ^
