it's a 800mah difference but i was just wondering if they just slapped a new sticker on there and upped the price a little. i have the 2700mah but the battery gets kind of hot after heavy use (hotter than the OEM) and the door doens't fit well. I'm looking into maybe getting another battery and hopefully a new door but i'm concerned with two things:
1. is there really any difference between 2700mah and 3500mah?
2. are all the extended battery doors coming from the same manufacturer?
thanks
thanks
