Root anyone have metro kdz file all links are dead
andriodadmirer
hello i have searched and searched but cant find the l70 metro kdz file anywhere where its not a dead link or has been deleted from a site akready can someone please share a metro kdz file here thanks
I entered my IMEI. It says that if failed authentication. I can't get KDZ, which means I can't get back to stock, which means I can't fix mobile data. I have tried the aboot fix. Didn't work. Tried the APN edit. Didn't work. My last resort is go back to stock and start over. Can't do that either. Please help. I'm desperate.
Then you did somwthing wrong, I know people with metro pcs downloaded kdz's this way.
Here you go, got it from my IMEI:
edit, hm, I can't seem to get mines either. This was a shortcut link.
I honestly don't know what I did wrong. I copied the URL from your post, pasted it in the address bar, replaced "IMEI" with the one from under my battery (tried both with the dashes and without) and it still didn't work. Was there something I missed?
You did alright. Guess LG changed something, since it doesn't work for LitrosNub also.
