Root Anyone have problems with Osmos or Zenonia 4 on CM7?
Caleo
I've been using CM7 for a bit now, and so far the only two apps I've had real problems with are Zenonia 4 and Osmos. Zenonia occasionally just hangs for several seconds at a time (no graphical changes, no interaction, but the music continues fine). Osmos on the other hand will do something similar but it usually results in the level restarting.
Does anyone else have similar issues? Any ideas on fixes to try?
PS: I restored my stock rom to try Zenonia; no freezes. Using CM7 TG-Reloaded
All games do this for me on CM7. They pause for a few seconds then continue like normal. This also happens when waiting for timer to go down on download websites eg. Megashare, Rapidshare, ect the timer will pause then continue running down.. its a known problem. I think turning off Wifi helps a bit
