Juanmendoza17
You should try "Greenify" this app helps a lot with battery consumption! I literally got the best out of my battery with this app. It works by "freezing" apps that run in the background. For example, "Facebook" that app always runs in the background and keeping track of push notification which drain your battery a lot so I suggest you try this app it's the best!
https://www.google.com/url?sa=t&sou...=BSFgcF-0NTHEy14QmFFmkg&bvm=bv.48340889,d.cGE
