A.Nonymous
Extreme Android User
Is anyone else running into problems with TB syncing with DropBox lately? I've had this problem for a while with TB FC'ing when I try to sync to DropBox, but just recently had a few minutes to actually sit down and try to troubleshoot it. Basically, here are the symptoms:
1. TB will back up everything just fine and scheduled backups run normally.
2. TB will sync everything to DropBox normally with no issues...until it hits the limit I've set of 5 backups per app.
3. Once it does hit that limit, it will enumerate the apps on my phone with no problem and then will fail the moment it goes to "scanning Dropbox target". Then I get a message that the sync to DropBox has failed.
4. If I hit the Sync to DropBox button again at that point, DropBox will FC on me.
I had thought that this behavior might have been because of the ROM I was using. I've now re-created this on three different ROMS though. Virtuous, Nils Business and Warm Z all have the same problem. If I go into my Dropbox account on my computer and delete all the files in the Titanium directory, it works just fine again until it hits that 5 backup limit. Any ideas?
