C Cimota Lurker Apr 19, 2011 #1 Hi all Just got my new Galaxy S yesterday (HTC Hero previously). Went looking for "Asphalt 5" in Samsung apps and it doesnt appear to be there. If I use the "search" function I find it but when I try to download / install I get an error message. Any advice appreciated.
A anwernizami Lurker Apr 19, 2011 #2 hey u can get asphalt from here: Or njoy!!!!! Snapper.fishes: Links removed. What do you think you are doing mate?
camevad Newbie Apr 19, 2011 #3 Try Appbrain on your PC rather than Samsung our Android Market. A small bit of setting up time but nicer to use/explore.
S snapper.fishes Android Expert Apr 19, 2011 #4 How are you downloading it? Have you tried using wifi?
C Cimota Lurker Apr 20, 2011 #5 I am indeed a Muppet. I thought it was only available for free from Samsung apps & didnt look in the "normal" market.. Just checked using Android Market, found it and downloaded it. Thanks for advice - may give appbrain a whirl at some point.
