Help Anyone with this problem ???
cacko
Hi ,
I change my SD Card ( from 2 to 4 gb ) and when i made update to 2.1 it was working perfectly , but now , when i connect to pc and get in the sd-card , the phone restarts ( turn off and then turning on )
Any sollution for this problem ???
Thanks
Hi ,
Thanks
It happened for me and for others also. Some people said this problem has been solved after the latest maintenance update (on 21/12/2010) from SE.
When you connect your phone to PC normally you will get few options like connect pc, install pc companion and charge phone. if u click any of those options the phone will restart. instead click back and mount your sdcard from the notification bar. It worked for me before i rooted my phone. now after rooting im not having this problem.
