Yes it is sealed. Dunk it in your sink filled with water. Dry it off completely, and then open the battery door. I've had mine under water twice. Every opening afterwards was completely dry. If you want to test it to make sure then just run it under the tap, and let the water run over it quickly, and then do the dry and check.
