Root AOSP ROM problem
lambo172
While using any AOSP ROM, I can't hear out of my right headphone. But, while on BAMF Forever 1.0.6., I can hear perfectly out of both of my headphones. I really want to use a bone stock gingerbread ROM, but this is keeping me from doing so. Is there anything that I'm doing wrong? And, yes, I'm wiping. I have tried using my headphones immediately after flashing, so no apps are getting in the way from my Titanium Backup.
Try switching kernels if you have not. If you used something in the Imo family, try using Tiamat or vice versa. Audio is more kernel related than ROM related.
I tried that, and it still didn't work :confused: And, i can hear out of the right headphone, but just barely when the volume is all the way up. What else could be the problem?
I've tried Pure Gingerbread]OMGB 1.2.0 and TheROM V4. And, im using wired headphones, and yes, they're plugged in all the way.
Both of those are OMG based roms. I have issues with them on my phone whenever I try to run them. I would suggest wiping fully (factory reset in recovery, wipe cache, wipe dalvik cache (in advanced), and format /system (under mounts and storage)) then reflash or flash an AOSP rom based on CM or CM itself. Really if you want a pure AOSP like experience then you just need to run the GB launcher with you can get from the market.
