apad/iped need honest review
djorder
Greetings fellow 'doids
thinking of getting and apad/iped/whatever its called this week :) but need a really honest review from people who have one.
also is it really able to be upgraded (as one seller says??)
thanx in advance guys
for $100 (shipped) or less you have a serviceable e-reader (kindle, aldiko) and there are several ROM's you can flash onto it. there is an update to the firmware which makes it decent and there's a CUSTOM ROM out there that is really zippy. you can try out android apps and the internet connection is not half bad. if you have low tolerance for the problems described, stay away...
Hey djorder, I just posted a review of it .. check it out at my signature link. It will not be upgradable to anything other than 1.5, this is all that rockchip will be releasing - but they have several bug fixes for it.
Can you post the review link? I checked all the articles but can not find your review for this tablet.
