Apex Launcher widget problem
oyvindpe
On my Galaxy S3 I have installed Apex Launcher pro. It seems that there is a problem though. The stock alarm widget gets messed up. The widget size is not correct and only part of the clock shows. I have to scroll or resize the widget to see everything, but then I see part of the next alarm...... Is there a way to fix this?
Here
Bumpuru.
I bought the app and had the exact same problem. Happens with a lot of widgets too :(. Shame, because I really love the launcher and can't use it with this problem. Any potential solutions people of the interwebs?
Bump.
Apex appeared to be the answer to my touchwiz issues. Scrollable wallpaper, easier to make folders, more stock ICS look. But, widgets just don't display the same. They appear as the wrong size and they aren't as easy to arrange. I'd love to hear if there's something I can toggle in settings to make things appear as they should.
