APK Batch Installer
HDKorp
Anyone know of an app that will create a batch install zip file of multiple APKs? This way, after a ROM install, one file can be installed containing 5, 20, or 50 APKs...instead of installing each APK individually.
My Thunderbolt has been Liquified
Titanium Backup is the only thing that comes to mind. If you back all your apps up with it it will re install them after a new ROM has been installed. Astro File Manager also has an app backup feature, but I have never used it to re install apps and I am not sure it has a batch feature like Titanium does.
I already use TB and Astro, but with both, you can only do one file at a time or all backed up files. There has to be some app out there that does selective files.
App Extractor Pro allows you to install what app you want from a nandroid backup. The free version limits you to 5 at a time (I think) but the pro version is only $2 IIRC.
you need to pay for the Pro version to allow it to restore multiple apps at once. its worth it.
I can't post links since I'm a new user, but if you're on windows, I wrote a windows based application that can do what you asked for above, it may or may not be helpful to you :)
forum.xda-developers.com/showthread.php?t=1531880
Funnily enough, it's called the APK Batch Installer Tool, which is pretty much the name of this thread as well :X
