I just switched to straight talk from tmobile, I purchased a tmobile sim card from straight talk. Popped it in ported my number and phone service works.
I put in the apn settings on the phone and its saved, but after about 10 seconds it goes back to the tmobile apn.
It sounds like Tmobile locked the settings on the phone so I cant use another carrier. Is there a way to delete the old tmobile settings, like a factory reset. Or would I have to root the phone?
Also for the tmobile apn there is a lock next to it.
Thanks for the help.
