Help Apn settings not sticking
t12b25
Hi everybody, ever since my 5.1 update my apn settings aren't sticking. As soon as I turn off and turn on my phone the apn settings change right there and then. I have to then go into the settings and select the right ones. Any fixes? Ideas? Help?. Any help would be appreciated.
thank you,
Anthony.
What carrier / APN are you using?
Hi sorry for the delay factory reset everything, and I'm still having the issue... I am on metro pcs... And the apn is...
APN: fast.t-mobile.com
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc is all of that correct?. Anything I need to add?. I need help the settings aren't sticking when I reboot the phone it switches to another apn... Appreciate the help,
Thank you,
Anthony.
And is your phone stock / unrooted, or have you perhaps enabled the LTE hack? (No judgment here, that's one of my favorite things about the N4, it just adds another layer of complexity.)
Yes stock unrooted I'm sure this phone would be much better rooted, but I don't even have a computer right now. Anyway, it switched on me again when I rebooted earlier didn't notice till later. Thank you for all the help, Anthony.
What other APNs are listed?
It may be worth a try to delete all the APNs except the Metro / T-Mobile one that you need.
I also found a thread for the Nexus 5 that describes a similar issue - maybe it can help you out: http://androidforums.com/threads/solved-nexus-5-t-mobile-apn-stick.808619/
Hey thank you for the help I'll try that out. Sorry for the delay yesterday we had a thunderstorm and it knocked out the electricity in half the house, then at 2:30 am they shut it all off till 5. Then at 2 pm today till now. I appreciate all the help good looking out
Thank you,
Anthony.
