Help APN settings
chukka63
I was looking into Vodafone APN settings and came across this,Pay monthly and Business
APN: wap.vodafone.co.uk
Username: wap
Password: wap
MMSC: http://mms.vodafone.co.uk/servlets/mms
MMS Proxy: 212.183.137.12
MMS Port: 8799
MCC: 234
MNC: 15
APN Type: default,mms
When i checked mine the APN Type was default,suppl,mms.Should i leave mine as they are or change them to whats listed above or does it not make any difference either way.
Username: wap
Password: wap
MMS Port: 8799
MCC: 234
MNC: 15
That's fine. You can add additional types to the list at will. However, if you do not know what they do then you shouldn't mess with it.
