Help apndroid and mms
Hi guys
I turn off 3g access from Apndroid, and use wifi only. But then I can't send recei e multimedia msgs.
But can make calls and regular texts
Im with ATT on motor bravo. Rooted 2.1
Apndroid app developer says mms apn has to be edited.
Is there any way around this or does 3g aalways have to be on to send receive multimedia messages ?
I went to the phones apn setting and all is locked, not highlighted to be able to change.
Thanks for any input.
I'm afraid MMS will work just over mobile network. If you have mobile data enabled, it's enough to turn off data with Apndroid (and leave MMS enabled).
What do you mean with "apn setting locked"? Basically, you have to enable data transfers in Apndroid and add MMS APN (settings depends on mobile operator).
I mean the apn options are not clickable in android (phone), not the apn app. The mms transfer within Apndroid is enabled all the time.
Even Apndroid developer says that function is not reliable.
